Brief Description: Vert stab component prep, start sht ONX-T07
Completed prep on following ONX-T08 components: -02, -03, -08, -10, -18. Completed -01, Vert Stab Root Rib Assy. Need part T08-17 (b/o) and bend on -07 to complete sheet ONX-T08.
Started on ONX-T07-01 assy.
PS 3/28/12: at this step, I should have considered updrilling T08-09 (rear spar strap) and T08--16 (tail spring doubler) to 5/8" at the 24.3 deg angle noted on sht L03-01 and -02 and installation procedure #1. It would have been much easier to handle for an accurate hole on a drill press.
